DS917072
[V50 Ultra] V50 Ultra does not find the base station and won't leave it
Yesterday I bought a new v50 ultra complete.
I followed the instructions, placed the robot in the docking station and started a quick mapping.
The robot stays in the docking station, states
- "start mapping [...]"
- "mop pads removed"
The sensor moves up and the robot stays in place.
- "mop pads off. Please install them before resuming"
If I remove the robot from the station and start a quick scan it scans my whole apartment, but doesn't find the base station.
I already tried a factory reset of the robot, but the problem is still the same
Is there anything I can do?
Gib es zurück oder tausche es um.
Hello,
Please check if the mop pads are properly installed on the robot. If the problem persists, we kindly suggest contacting the seller or reaching out to our customer service with your device's serial number and purchase invoice for further assistance. We apologize for any inconvenience you may have experienced and are here to help ensure your satisfaction.
Thank you for your understanding.
UID:DS917072
