PV368068
[LiDAX Ultra 1600 AWD] Mowing closer to or on a terrace with an existing map
Hello everyone,
I have a question regarding an already created map.
Is it possible to adjust the map so that the mower also drives onto the terrace paving stones in order to mow the edges properly?
At the moment, about 15–20 cm of grass is left uncut along the terrace borders.
Can this be added or modified afterwards, so that the mower slightly crosses the edge and cuts the grass right up to the border?
Thanks in advance for your help!
Hello, you can try expanding the existing zone. The operation is same as set zone. If the newly created zone overlaps with the original zone, the two zones will automatically merge and form a newly expanded zone.
Hello,
Since the mower is currently leaving a wider unmowed strip along the terrace edge, you can try expanding the mowing area with the steps below:
Ensure that your phone is connected to the mower via Bluetooth. Use the remote‑control function in the app to move the mower to the area you would like to expand, then tap “Set Starting Point.” From that position, continue to remotely control the mower along the boundary of the area you want to add. The outline of the new area will be displayed in real time in the app.
When the mower returns close to the starting point you set, tap “Close Outline” in the app to complete the area expansion.
Kind reminder: When expanding an existing area, the newly added section must overlap with the original mapped area. After closing the outline, both areas will automatically merge.
Das mit dem erweitern wird nicht funktionieren. Das ist ein Software Problem.
UID:PV368068
