WZ395442
[MOVA 1000] Auto map swap
Dieses Thema wurde zuletzt von WZ395442 am 2026-3-20 12:20 bearbeitet
Greetings! I have two MOVA mowers covering four patches of land.
The first two are separated by stairs, such that each has its own charger and I carry around the mower regularly, then select the other map within the app.
The second two patches are connected, such that I have placed one charger in their middle, and created two maps.
Every other day I want the robot to mow the one or other patch. Currently I achieve this by daily opening the app and swapping the selected map.
Can this process be automated within the app, it do I need some external android macro?
Best Regards, Andreas
Hello, thank you very much for explaining your usage scenario in detail. We fully understand the need for planning with multiple maps.
Regarding your question about whether it is possible to automatically switch maps within the app to perform mowing tasks, the current situation is as follows:
At present, automatic map switching is not supported.
The schedule will only execute mowing tasks for the currently selected map.
When two maps are available, it is necessary to manually switch the map in the app before starting the corresponding mowing schedule.
Thank you very much for this valuable suggestion. We have forwarded your feedback to our product and R&D teams so they can consider possible optimizations in future updates.
We sincerely apologize for any inconvenience this may cause and thank you for your understanding and support.
UID:WZ395442
